Would you add the ability to fast forward and rewind in stages, example:
when playing a long audio file, when the user clicks on options theres now two extra options
Fast Foward>
Rewind>
when you go into its sub options you see
Fast Forward> 1 Minute
2 Minutes
3 Minutes
4 Minutes
5 Minutes
ofcourse it won’t allow you to fast forward by 4 minutes if your listerning to a 3 minute file, so it would have to check the files length and then light up the fast foward times that can be used to prevent people crashing there players.
