Fail to open file
Error message appears in secured folder as screen shot
Anyone one know the reason and solution ?
it looks like there is some issue encrypting the file. Does this only happen with that particular file or are other files affected as well? If it is only that file it may be a corrupted file issue.
My files wont open either, exactly like the picture abow. My whole life pictures are on that USB stick. What can I do??
