It can take several minutes to appear on my Windows 10 PC, yet if I connect my Corsair Flash Voyager GT it appears instantly !?!?. Both drives formatted NTFS.
Do these drives have a driver that may need installing/updating or is it a common drive issue ?
In order to check speed of your flash drive we recommend you to please use below software to make a general assessment of your testing.
• To download the software, please refer to below link:
• Run the file and Install the software by following the installation wizard.
• Once the software is installed, please locate the “CrystalDiskMark Application” icon on the desktop
• Double click the icon and then select the SanDisk flash drive in the Device box.
• Run the speed check read & write speed.
• Once this process will complete, share screenshot of test results with us on support@sandisk.com
Hi there! It sounds like you’re experiencing some issues with your external drives on your Windows 10 PC. It’s possible that the drive may need a driver update, but it could also be a common issue. Have you tried troubleshooting the issue with the Windows 10 troubleshooter? That might help identify the issue. Additionally, you might find some helpful information on the ““windows 10 reddit key”” thread. Best of luck!
