My Extreme Portable SSD (Model: SDSSDE61-2T00) is blue screening my device when i plug it in. I tried plugging this SSD into 3 different devices and all of them get blue screened after about 15-20 seconds. There is around 1.4TB storage still left on it. I used this SSD for about a month now and this problem came up yesterday after i came home and tried to acces the files in the SSD
Experiencing a blue screen error when connecting your SSD to multiple devices indicates a potential issue with the SSD itself. You can try a few things that for this issue
Firstly try checking on other computers
Ensure that your computer’s USB drivers are up to date
Visit the manufacturer’s website and see if there are any firmware updates available for your SSD
If you are unable to do it then try contacting the support.
Ensure that all system drivers and the SSD firmware are up to date. If possible, run a file system check using chkdsk. Try using a different cable while plugging in the device. If the problem persists, back up your data and format the SSD. Providing the exact blue screen error code can also help in diagnosing the problem.
