upon first using it… it didn’t detect right away… so I removed it, and re-inserted it… came up right away. wanted to start moving files there. Tried to create a new folder, However, it would cause the windows explorer window to stop responding… then afer a few seconds would come up with an error (file system error (65535).
I tried to create a text file, that worked… and could even modify the file and save…
Has anybody an idea why these drives are retailed with been formatted to FAT32, not to NTFS? NTFS should provide more performance, or am I wrong here? How safety is it carry this drive with a small bunch of keys. 3 keys: flat + post box? You know how the bunch of keys is normally handled. Any rubberized case available for this drive on the market?
They are in FAT32 for compatibility. NTFS is not compatible with all OS where FAT32 is. IN addition to that NTFS you should always use safely remove media before removing because it is a journaled file system. The best format for removable drives now is exfat. None of the limitations of FAT32 but there are still some OS compatibility issues with exFAT.
Carrying the drive on a key chain should not be an issue. I have the same drive on my keychain with no issues. I have not seen any sleeves for this drive.
> Carrying the drive on a key chain should not be an issue. >I have the same drive on my keychain with no issues. I have not seen any sleeves for this drive. Really? You know how a keys bunch is normally handled. Mechanical shocks are normality. As far as I know mechanical shock is killer for flash chips.
