External Drive Only Showing Not Working
I have a WD Elements 25A2 Device it shows in Device Manager but is not accessible. It says the device is not migrated on both my 64 bit laptops and it is a 32 bit device.It says the device is working and the driver is up to date. Is there an easy solution for this external drive which appears to be empty but may well have been used before. Speccy says on Status everything is good. My computer knowledge is limited.
It shows in Disk Management but solutions are greyed out.
It sounds like you’re experiencing an issue with your WD Elements 25A2 external device not being accessible on your laptops. If the device is showing up in Device Manager but you’re unable to access its contents, there could be several potential reasons for this problem. Here are a few steps you can try to troubleshoot and potentially resolve the issue:
  1. Check Drive Letter and Assign One (Windows):
    Sometimes, a drive may not be assigned a letter, preventing it from being accessible. Follow these steps to check and assign a drive letter:
    • Right-click on the “This PC” (or “My Computer”) icon on your desktop or in the File Explorer.
    • Select “Manage” to open the Computer Management window.
    • Click on “Disk Management” in the left pane.
    • Locate your WD Elements drive in the lower section of the window. It might appear as an unallocated or unrecognized drive.
    • Right-click on the drive and select “Change Drive Letter and Paths…”
    • Click “Add” and choose a letter for the drive, then click OK.
  2. Update or Reinstall USB Drivers:
    Sometimes, USB drivers can cause issues with external devices. Try updating or reinstalling the USB drivers for your laptop:
    • Open Device Manager (you can search for it in the Start menu).
    • Locate the “Universal Serial Bus controllers” section and expand it.
    • Right-click on each USB-related entry and choose “Update driver” or “Uninstall device.”
    • Restart your laptop after updating or uninstalling the drivers.
  3. Try a Different USB Port and Cable:
    The USB port or cable you’re using might be faulty. Try connecting the WD Elements drive to a different USB port on your laptop and use a different USB cable if available.
  4. Use a Different Computer:
    If possible, try connecting the WD Elements drive to a different computer to see if the issue persists. This can help determine if the problem is specific to your laptops or if it’s related to the drive itself.
  5. Data Recovery Software:
    If you suspect that the drive might have data on it, you can use data recovery software to attempt to retrieve the files. Programs like stellar could help you recover data from the drive even if it’s not accessible.
  6. Contact WD Support:
    If none of the above solutions work, it’s a good idea to contact Western Digital’s customer support. They might be able to provide specific guidance based on the model of your drive and the symptoms you’re experiencing.
Remember that working with hardware and data recovery can sometimes be complex, so if your computer knowledge is limited, it might be beneficial to seek assistance from someone with more technical experience or a professional technician.
Solution by Change Drive Letter may be the answer I can see it but its greyed out. On both my laptops.
Hey, Dodgin. When you plug in an external drive, you usually go to Computer Management to change its drive letter. If it’s greyed out, it might be formatted on a Mac, using a file system unreadable by Windows. To read Mac-formatted drives on Windows, you’ll need a small, free application called HFS Explorer.
Here’s how to get it:
  • Open Google Chrome and search for “HFS Explorer”.
  • Avoid clicking on ads; go to their official page.
  • Download and install it for Windows.
You may also need to install Java to run the application. Once installed:
  • Open HFS Explorer.
  • Connect your external drive.
  • Click ‘File’ > ‘Load file system from device’.
  • Click ‘Auto detect’.
  • Select your Mac-formatted drive and click ‘OK’ to view your data.
You can extract files to another location on your PC, but you can’t write back to the same drive yet. To make it writable:
  • Open Command Prompt as Administrator.
  • Type ‘diskpart’ and press Enter.
  • Type ‘list disk’ to identify your external drive.
  • Select your drive with ‘select disk X’ (replace X with your drive number).
  • Type ‘clean’ to format the drive.
Next, back in Computer Management:
  • Go to Disk Management.
  • Right-click on the unallocated space of your drive.
  • Choose ‘New Simple Volume’.
  • Follow the wizard to format the drive as NTFS.
For more information, you can check: 7 Quickly Fixes for Western Digital External Hard Drive Not Showing up?
You can start by verifying whether the WD Elements external hard drive appears in the BIOS. After that, follow additional troubleshooting steps:
  • Disconnect the WD hard drive from Storage Spaces
  • Remove all ATA channel drivers
  • Download and install the SATA driver from the motherboard manufacturer’s website.
Related tutorial: https://iboysoft.com/howto/hard-drive-not-showing-up-in-disk-management.html
My WD Elements 25A2 external drive appears in Device Manager but is not accessible and shows a “device not migrated” error on both of my 64-bit laptops. This usually happens when Windows cannot initialize the drive due to driver or firmware issues. The fact that it is a 32-bit device does not cause a problem. To fix it, try using a different USB port or cable, uninstall and reinstall the device driver, check Disk Management to see if the drive appears and assign a drive letter if needed, or use WD Drive Utilities to check the drive’s health. If the partition is corrupted and appears as RAW, data recovery software like Stellar Data Recovery, R-Studio, TestDisk, or GetDataBack can be used to recover the files without formatting.
You can try this: first, disconnect and reconnect the drive to a different USB port. Then, open Disk Management to check if the drive shows a partition or is marked as RAW/unallocated. If so, you can right-click the drive, choose Change Drive Letter and Paths, or try updating/reinstalling the USB controller in Device Manager to make it accessible. This video might be helpful to fix an external hard drive.
