error code -8062
I am growing very annoyed with this SSD portable… Why I am getting "The operation can’t be completed because an unexpected error occurred (error code -8062)
Hi @CTS,
The error code -8062 is a generic error code that can be caused by a variety of problems. The drive is corrupted or you may have to format it. Or, the drive is not properly plugged in.
Try using a different USB cable or updating the firmware to see if that fixes the problem. You can also utilize some recovery software like Stellar or Recoverit to access the files from the drive.
The “error code -8062” on your portable SSD could be due to file system corruption or a conflict with the operating system. To resolve this, try repairing the file system using disk utility tools on your computer. If the issue persists, formatting the SSD might help, but ensure you have backups of important data. If problems continue, contact the SSD manufacturer’s support for further assistance.
If you experience any data loss, we recommend trying the popular software Easeus.
