Any way to drag and drop onto this HD instead of the software? Might jsut be me but I find the backup wizard cumbersome. Any help would be appreciated ![]()
Yes, you can drag and drop the files to it…
If you goes to my computer, you will see the my passport icon and you can open that create a new folder and move the files manually to the drive
