DLGDIAG 1.25.0 is unable to properly read any SMART values for disk which are connected via USB. Example below compared to another tool which can.
System:
Windows 7 x64 SP1
Asus P8Z77-V
Thermaltake BlacX 5G HDD Docking Station via USB 3.0
System:
Windows 7 x64 SP1
Asus P8Z77-V
Hi, I recommend you to contact Thermaltake support.
S.M.A.R.T. attributes supported by WD EIDE and Serial ATA hard drives
What exactly would I report to thermaltake? WDC disk diagnostic tool cannot read smart values but another tool can. So clearly it’s then not a problem with the USB enclosure but the software…
WD doesn’t support external enclosures. If the parameters are correct when testing the drive directly connected to the Motherboard then I do not personally believe there’s much left to do since WinDLG would be working as intended by WD.
Regards,
