How can I recover data from my 1TB Portable External Hard Drive that is making a clicking sound when plugged in to the USB Port but does not show up on the PC when connected?
Sounds like the āClick of Deathā. Check out this earlier post. You can also web search and find many similar issues.
If your drive is making a clicking sound it likely has a serious mechanical issue. I suggest you start by checking different cables, ports, or another computer if the drive becomes recognizable. If it occasionally shows up use Stellar data recovery software to scan and recover files if the drive isnāt recognized and sound continues use the professional data recovery service, as they can handle hardware issues. I would highly advise you to stop using your drive before going for these methods.
The clicking sound is a red flag. It usually indicates that the read/write heads of the hard drive are hitting the platter incorrectly. This can happen due to mechanical failure or physical damage.
When your hard drive starts clicking but doesnāt show up on your computer, the safest and most effective thing to do is contacting a professional data recovery service. They have specialized equipment and clean room facilities that allow them to open up the drive and attempt to recover your data.
A constant clicking noise can be a sign of physical damage to the driveās internals. If the clicking is repetitive or inconsistent, it may be a āstuckā read/write head, which usually requires professional repair. If the clicking stops after a few moments and the drive shows up, there may be a temporary issue. This full guide may help:
A clicking hard drive means itās failing. Try a different USB cable, port, or computer. If itās in an enclosure, connect it via SATA. Check Disk Managementāif the drive shows up, assign a letter or use recovery software like Stellar Data Recovery. If nothing works, freeze the drive for a few hours and try again. If it still clicks and isnāt detected, stop using it to avoid damage and consider professional recovery.
For more help, check this blog: How to Recover Data from Clicking/Noisy Hard Drive
Iād suggest checking out the status of the hard drive first.
Use Disk Management on Windows PC:
Press the Windows + X keys on your keyboard and choose āDisk Managementā from the menu. In the lower panel, find your WD portable hard drive.
If the drive doesnāt have a letter assigned (like I: or J:), right-click on it and select āChange Drive Letter and Pathsā to assign one.
If you canāt see the portable hard drive in the list, there may be an issue with the drive itself or its connection. The sound coming from your hard drive typically signals either a power issue or a physical problem, such as a head crash where the read/write heads are stuck.
To troubleshoot, try updating the USB driver on your computer, use the CHKDSK tool to check for errors on the SSD, or inspect your BIOS/UEFI settings. If youāre unsure how to proceed, follow the steps provided here: Hard Drives Not Showing up or Working? One-stop Guide to Fix
