Sir,
I had purchased two SD Card 16GB through Flipcart ,Delivered on 31.07.2014.Since then both are working but yesterday one of them showing Damaged SD Card message and stopped working. I had checked it on card reader also but not working.
please help .
Thanking u
Niranjan Sharma
I would contact Flipcart and tell them the card has failed. It should be soon enough after purchase that they would replace it for you.
If not, you can contact SanDisk directly for a warranty replacement:
http://www.sandisk.com/about-sandisk/contact-us/
