Hey all,
I just got my Fuze 8GB v2 player and have discovered a problem with the custom EQ setting. The song will continuously cut in and out when being played. It plays fine in all other preset EQ settings (though it sounds lousy).
Thanks for any help.
Make sure your headphone plug is inserted all the way into the jack. They are extremely tight from the factory. This could be causing your issue. Try twisting it as you push on it to insure it is fully seated.
Wow, that did it (and it was so simple!) This player sounds fantastic now!
Thanks for the help from a newbee! :smileyvery-happy:
You’re welcome! Enjoy the toy!
