I just bought the hard drive a few months ago and used it once to back up my desktop computer. It worked fine. I just plugged it in again. I first got a message that a driver was being loaded, then a message that the driver had been successfully installed. The WD elements does appear on the “Computer” screen, along with my C: drive and other devices.
The problem is that the cursor is almost completely frozen. It’ll freeze, then move very jerkily, then freeze again. I unplugged the WD drive, restarted the computer with the drive plugged in, and I get the same result. As soon as I unplug the drive, the cursor operates normally, as does the rest of the computer. I can’t use the computer in this condition…it takes forever to get the cursor to move just a few inches.
Forgot to mention: I’m using a Dell PC with Windows 7, 64-bit operating system.
Try to run a diagnostic on the drive if possible to see if the drive has any issues, also try to connect it on a different computer or using a different cable. Try to run the Diagnostic using DLG this is the software download link:
It passed the SMART test, but the cursor is still frozen. I assume the cable is good, since it passed the test. The drive worked fine on this same PC in October, 2015, and I haven’t tried to use it since. Any ideas?
You are brilliant! Based on your question (“what’s changed?”), I just figured this out and believe someone needs to let Western Digital know of the issue. A few days after I received the WD drive and backed up my PC (using my old wired mouse), I received my new Amazon Basics Wireless Mouse with Nano Receiver (Black). It has a small USB receiver, which I plugged into the front USB slot on my PC.
Yesterday, when I went to use my WD drive, I plugged it into the second USB slot on the front of my PC. This slot is immediately adjacent (3/8") to the other slot, that had the wireless receiver plugged in. When I plugged in the WD cable, the mouse/cursor froze. When I unplugged the WD cable, the mouse/cursor was fine.
I just experimented with a wired mouse, plugged into the front USB jack next to the WD USB. No problem…the mouse/cursor is fine! Then I tried plugging the Amazon receiver into another USB jack on top of the computer, about 8" away. It also works fine!
Apparently there is some sort of intererence between the Amazon receiver and the WD USB cable, when they are in close proximity. (I should note that the front two slots are USB-3, with the SS symbol, and the slot on top of the computer is a USB-2).
Thanks, and please pass this along to WD if you can! (I’ll put a note to the same effect on the Amazon wireless mouse comments page).
Hi Dan and everyone else who has had this problem. I confirm that proximity of my brand new WD Elements 2Tb HD cable (USB3) to the wireless mouse/keyboard receiver (in my case, a Dell) interferes with and causes the mouse to freeze/behave erratically. Moving the wireless receiver to a USB port on opposite side of PC has cleared the problem. So glad I saw this thread and thanks.
Wow! Same worked for me (moving drive to USB-hub connector on the other side of laptop)!
Laptop Dell Latitude 5520, wireless mouse Logitech MX Master 3, and WD drive 18 TB.
I do not believe it’s drive’s fault though, - probably Windows gives drive higher priority than to a mouse (probably not knowing it’s a mouse on USB) when on connected USB pair of ports.
Dan you are the man. I have the 8TB Easy Store External plugged into my Laptop. I had the same issue. Every time I turned on the WD drive the curser would freeze up and jerk around slowly. If you could manage to get the curser to the right spot, the external would transfer and store files just fine. But that curser freeze up really drove me bananas.
At my wits end and considering changing to another brand’s hard drive, I went to Google and found this statement.
Apparently there is some sort of interference between the Amazon receiver and the WD USB cable, when they are in close proximity. (I should note that the front two slots are USB-3, with the SS symbol, and the slot on top of the computer is a USB-2).
Wow!!!Eureka!!! That was it. I switched wireless mouse into a port that was not adjacent to the External drive’s USB port. I am one happy camper. Thank you so much for your posts and your perseverance to figure this issue out. That is a 2 year thorn out of my side. Everyone who participated in Dan’s query, a big thanks for your help. No more freezing curser. Yay!!!
If your cursor freezes when you plug in a Western Digital (WD) Elements 2TB USB 3.0 hard drive, this typically results from driver conflicts, USB power settings, or system compatibility issues. Follow these steps to resolve it:
Check USB Port: Try connecting the hard drive to a different USB port, preferably a USB 2.0. This helps isolate compatibility issues.
Update Drivers: Outdated drivers may cause conflicts. To update them:
Open Device Manager (press Win + X and select Device Manager).
Expand Disk Drives and Universal Serial Bus controllers.
Right-click on the WD Elements drive and each USB Root Hub, then select Update Driver.
Restart your computer afterward. Learn more about updating drivers on Windows
Adjust USB Power Settings: Windows might disable the USB port to save power:
In Device Manager, right-click each USB Root Hub.
Go to Properties > Power Management tab and uncheck “Allow the computer to turn off this device to save power.” See more on managing USB power settings
Run Disk Check: Plug in the drive, open This PC, right-click on the WD Elements drive, select Properties > Tools > Check under Error checking. This helps identify and fix file system issues. Guide on checking and repairing hard drive errors
Update System BIOS/Chipset Drivers: BIOS or chipset incompatibilities can cause USB issues. Visit your motherboard manufacturer’s website for the latest BIOS and chipset drivers. More on updating BIOS
Try Another System: Test the hard drive on another computer to rule out system-specific issues.
If these steps don’t solve the problem, contact Western Digital support for further assistance, as there could be a hardware fault.
