Hi! I tried to create a Windows XP SP3 32bit installation on my Sandisk Cruzer Titanium USB 2.0 pendrive. For this, I used the Novicorp WintoFlash and the process stack in the middle… Then I formatted the drive and since that time the drive is not shown on My Computer just in the tray icon and HDD management in Windows. In other computers it is recognized and shown properly under “My Computer”…any opinion on this?
Hi Alexous,
Dear member of SanDisk Community, welcome.
[In other computers, it is recognized and shown properly under “My Computer”…]
Well, then the Cruzer is fine.
The problem, seems to be in your PC, try the other pendrives, to see what happens.
Luck, and then you tell us, what happened, please.
Regards, Alfred. (Google translated)
In Disk management can you manually assign a drive letter to the drive?
Why did you format the drive after running WintoFlash on it?
Thanks Ed_P… I went to Disk Management and assigned a letter to the drive…everything is fine now…
I formatted the drive because after the failure, I was not able to use it at all…
