leoc4
1
New problem started early January 2014 - my SanDisk Cruzer Titanium 8MB causes my Win7 laptop to crash each time I insert it.
- It doesn’t cause any problem in my Windows Vista PC.
- Other USB memory sticks can be inserted and removed from my laptop without any problems.
- If I start my laptop with the Cruzer USB memory stick installed, everything works just fine.
What is causing Win7 to crash? I’m tired of getting the BSOD each time I use my Cruzer.
ed_p
2
You are running an app on your Win 7 machine that is conflicting with the Cruzer. It could be Samsung’s Kies or one of a number of others. See if this thread helps you: http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Windows-7-Explorer-not-showing-drive-while-it-shows-in-computer/m-p/290694 It refers to several apps known to cause problems.
You can usually check this at event viewer too. Just hope that it will give you a log which software is conflicting here aside from Samsung Kies.
