Cruzer Blade 8GB Red and Black shows as Local Disk
I have a Cruzer Blade 8GB Red and Black which shows as Local Disk. I am actually trying to make the drive bootable and my software does not recognizes my drive as it shows as Local Disk in My Computer. I have tried Windows XP, Vista, Windows 7 and 8 as well.
A swift response would be appreciated.
Thanks!
Sunny Ahuja
I have the exact same problem as Sunny. Any help would be much appreciated.
Newer Windows 8 flash drives are made to be fixed disks rather than removable.  A new Microsoft standard to support Windows to Go.  The utility RMPrepUSB will make them bootable and I suspect as time goes on other utilities will get updated to support the new flash drives also.
You could also try looking for flash drives that are not Windows 8 compatibile.
Kudos to you, fine sir.
