Hi, I’d like to buy a My Passport Wireless Pro 4 TB. I got a Promotional Code but unfortunately it doesn’t work on my order (invalid code). Can someone tell me, where the problem is? Codes are valid.
Thank you!
Thank you!
Hello, Zara65
Maybe you should try contacting WD’s Technical Support about this.
http://support.wdc.com/support/case.aspx?lang=en
