I have the WD My Passport Pro (4TB) for use as photo file backup while traveling. Thus, I set up a filing system on the WD (Australia>Date, New Zealand>Date) to which I would like to copy to from the SD cards each evening.
However, I see no way to select where I wish the copies to be saved. In my test run it simply copies all new files to a “IMPORTS” folder and creates a sub folder for that date’s import. I then can move them to my specific preferred folder.
Am I so limited, or is there a way to chose where to copy?
I am pretty sure the Imports folder is the only place, but check jn either the 3 bar or 3 doi menu for choices, or check the complete user manual.
