I want to use “My Passport Wireless Pro” for copying my Sony XDCAM Camcorder files.
On copying of files does it keep the same folder structure and does copy hidden files?
Thanks
Thanks
If you do a copy/paste then it will copy the folder with the exact folder structure and hidden files.
I mean the automatic SD card import. Manually it’s normal to do that (for example from windows explorer)
Yes, it will copy all files and folders.
Thanks
