To connect with the Audible Manager, you need to have MTP mode active.
This is easy to test. Plug in your Fuze, then open a Windows Explorer window by pressing [Windows key] + E or go to My Computer. The Fuze must be listed as a media device under other. Double click on the Fuze, and you’ll see Internal Memory, then one more double click to open the root directory. If everything is OK at this point, we can approach the Audible client.
Please note that Audible is a wee bit different with the Fuze. There have been some updates in the background. Most notable is that you must use Audible Format 4 with the Fuze. If you have books in your library downloaded in Format 3, you can set up future downloads to be specific to the Fuze (I have Format 3 selected for my other Sansas, and Format 4 set for when the Fuze is connected). Audible allows you to download either version readily for your Sansas, so you can have both formats in your library.
Let’s address the Audible Manager. With the client open, you can click the Help > Updates function (sorry, I am on a terminal without the AM available at the moment), and reload the SanDisk Digital Players plugin, as this has been updated for the Fuze.
The other step is to go to the Audible website and download the new Audible Manager. They have fixed this process to make it easier: You CAN update by clicking the online library button, then go to support by the new open web browser that pops up.
The new manager installation has been updated to allow an “on top” installation, making repairs of the client a snap. Simply click on the download button, and let 'er fly. A window will pop up during the process noting that you will be repairing an existing installation.
You can also do it the old fashioned way, uninstalling the Audible Manager, then reinstalling a new copy. Your library will remain- I’ve tested it under fire with my own installation.
One last thought: if you reinstall or update, play it safe and be sure that the SanDisk Digital players plugin is loaded.
Bob :smileyvery-happy:
Message Edited by neutron_bob on 03-15-2009 11:41 AM
