Hey everyone,
i’ve got a problem with my Mybook Duo.
I used the new version of WD Drive Utilities to manage the Mirroring Raid Function. It worked.
I transfered all the data to it and a little while after that it showed a message with RAID configuration Failing. The red lamp of the second harddrive and the whole is blinking. And the message is coming every few seconds.
So i already ordered a new one. The same here. Is there anything i can do?
Thanks everyone!! ![]()
Hi mfstudiode,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support if you are having trouble with the form.
