How could I connect my external hard drive to my smartphone with Android 10? Is it possible to use the same adapter with which I connect to a USB stick?
Thanks.
Nobody? ![]()
I solved the problem with the help of android applications, Microsoft exFAT / NTFS for USB by Paragon Software and Total Commander.
