Complete test not supered
In August , I bought an external WD Mybook for MAC.
For a week all right, then suddenly, when the MAC turned on, the WD did not appear. Not even activating from WD utility.
After a few days, I do not know why, it has reappeared.
Apparently everything works fine, reads and writes.
But by doing WD Drive Utilities, CHECK OK, QUICK TEST IK, TEST COMPLETE: COMPLETE TEST DELL? UNIT NOT SUPERED.
What should I do?
Hello adriano2,
Maybe you should try contacting WD’s Technical Support about this.
http://support.wdc.com/support/case.aspx?lang=en
