What does it mean when I get Complete Drive Test failed
Hi there,
It might mean that you unit is defective, however to make sure this is the case, try to run another test on a different computer. If you are experiencing errors when you try to copy to the drive or accessing data could also mean you have a defective unit. My suggestion is to always try on a different computer to see if the same result comes up.
