Compatability Question with SanDisk 1TB Extreme Portable SSD, ThunderBolt 2 and my iMac 21.5” Late 2012
Compatability Question with SanDisk 1TB Extreme Portable SSD, ThunderBolt 2 and my iMac 21.5” Late 2012. I getting this cable and adapter.
1.) Thunderbolt 2 Thunder Bolt 2 Port to Thunder Bolt 2 Male to Male Video Data Cable and the
2.) Apple Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter.
Will it work?
I will be using it to back up my old iMac with Time Machine and then reformating the existing 480 GB internal SSD drive that I replaced in the iMac 21.5” Late 2012 Computer.
I want to reformat the internal 480 GB SSD Drive a do a clean Mac OS Catalina install to see if i can fix some issues i have been having before i migrate over to a much newer 27” iMac.
I wanted to get a newer USB-C external SSD Drive (Sandisk SSD Drive) that I can also use on my newer 27” iMac.
Please let me know if I will have any compatibility issues with my old ThunderBolt 2 iMac Late 2012 computer\ and the Sandisk 1TB Extreme Portable SSD.
Thanks,
RobertnBoulder
Hi @Robertnboulder
