I installed clubsandisk on my pc and cannot get rid of it. I cant locate it on my windows uinstall. anybody know the name of this beast?
club sandisk does not actually install to your PC. all it does is run from the .exe file. close the app and delete the .exe file and it will be gone.
This software is not that heavy. You can probably just ignore it for the meantime. You’ll never know, you might need it in the future.
