Owning the iPod Nano, and now the Clip Zip, I thought I would make some comparisons between the two. Bear in mind that the Nano is almost 3 times the price of the Zip, but there are some similarities.
First some history. I owned the Sansa Clip then in October 2009 I got the Clip+. I got a Nano in October 2010, but its sleep/wake button broke and I gave it to a friend. I got the new Nano at the beginning of October this year, then the new Zip just last week.
Partly why I’m making this short review is the similarities. The Zip has a colour screen, of course, and it seems that Sandisk have perhaps copied or used the Apple interface, or maybe from Creative. What I mean is that you can tailor the menu to just show the features you want. This is excellent; in the case of the Zip I just use Music, Settings and Sport (I like to have a timer function); and, in the case of the Nano, Music, Settings and their Fitness program. In both players these just scroll horizontally and you select the mode you want.
To me, (and I’ve tried out many players in the past with some fairly good iems) they both sound excellent on a flat EQ setting; moreover, the EQ settings on both aren’t bad at all (if you have some buds or 'phones that really need it, then the options on both the Sansa and Apple are perfectly adequate - just don’t go overboard.)
The FM radio on both is good - the Zip allows you to record, while the Nano lets you pause for 30 minutes.
Playlists on-the-go are perhaps better on the Nano - the Zip will let you create 2: a go list, and a Top Rated list, (and this is better than most players) while the Nano has no real limit to the number of playlists you can create on the device itself.
Of course, the Zip lets you drag and drop whereas the Nano needs iTunes or Media Monkey to sync content.
A problem with the Zip - thus far - is that you don’t get such detailed track information - time elapsed/ track count etc. as you do on the Nano. And this is in part due to the fairly low-res screen. But this is to be expected for a £40 device versus a £110 player. The fact that the Zip is colour is pretty good considering the price point.
In short: I love them both - they have differing uses… and the Zip does offer a great deal more for a lesser price, with the promise of further firmware upgrades and Rockbox.
