im in win 7 and when i try to past a 5giga file to the usb my computer sayes that i cant because ther is not space for 5giga, the USB is empty… pls help :cry:
Maximum file size you can store is 4GB and on a 8GB USB you can store 2 files that size.
The file size limitation is due to the format of the device, which is FAT32. If you reformat the device to NTFS it can hold larger files, but you will loose all your files and any software installed on it.
