Hi , I have accedentely deleted the software on de wd elements 1tb drive,and can not enter the drive anymore.
is there a solution for this problem ?
Thanx ,Jo
Thanx ,Jo
Deleted what software?
hi,
do you check hard drive condition in device manager and disk managment?
The software that comes with the drive, the setup.
it’s G?
yes it’s G.
Momentarely running a recovery prog. , takes 4ever . mayby it delivers…
You can download the software at http://support.wdc.com
oke,but how do i get it on to the drive,i cannot enter it ??!!
There is no need for software to be ON the drive.
The software is installed on the machine,still not able to enter drive.
You’re not understanding me.
Software is NOT required to use that drive. It’s an ordinary USB drive.
Now, if it was one of WD’s encrypted drives (like the Passport), then you’d need to use the WD Unlocker software.
The reason the drive is marked as “RAW” is because the file system is corrupted.
oke,but wat can i do to enter the drive ?
open software. then it show up a window asking for password. type password you will open this drive. it should be something like this? you can search such video on youtube.
problem solved ! Utube rules !
