Using a “My Passport Wireless”, Firefox Browser I have been tring all day to connect but it keeps coming back “timed out” and does not connect. Ideas please.
Maybe a dumb question, but are you using the MPW-provided SSID, not your normal Wireless network?
also, if you have VPN on the computer, try turning that off.
Hi mate…using normal Wireless and VPN not turned on…it is becoming
very complexing.
Thnx for your imput.
Bill G
very complexing.
…then you can’t use that specific IP.
You only use that specific IP when you’re using the MPW-provided WiFi.
If you’re connected to your normal WiFi (and your MPW is, too) then it depends on how you’ve configured the MPW.
Tony, you got it!! Thnx
You can save a shortcut to access and add content to your My Passport
Wireless. The shortcut can be used when you’re connected wirelessly to the
My Passport Wireless Wi-Fi network.
The shortcut will be downloaded to your browser’s default download
location. Typically this is your Downloads folder on your PC or Mac.
Cheers
Bill G
If you dig into the settings, you can set the MPWP to use a static IP address. . . .makes everything easier when creating shortcuts and what not.
Also, if you make the drive “visible” to the network on Windows, it will show up in the “network” group of windows explorer. . . .(as long as the drive is “awake”)
