Can you sync data from two drives on a PC to mycloud?
I have been using smartware 2.4.6 on Windows 7 to sync/backup (using catagory backup) my c: drive continuously. I would like to continue with the category backup/sync on drive c: plus sync/backup a folder on a different drive.
Can anyone tell me how to do this with smartware or can someone reccomend software that would help me do this?
Thanks in advance for any suggestions.
Steve
Smartware will allow you to create separate backups for different drives, but not at the same time.
On the WD Smartware “backup” tab you should be able to select the drive that you want Smartware to backup.
Thanks for the clarification but I really want to be able to do continuous backups on two drives at the same time. I receive a new My Cloud Monday as mine seems to have issues and I’ll keep looking for software to allow backup of multiple drives at the same time.
Steve
