Are itunes downloads compatible with sansa fuze? plz help! ![]()
One word. No ![]()
They are DRM protected and, sadly, the Sansa doesnât support that
Some arenât DRM âprotectedâ (though most are)âŠbut even the ones that arenât use a format that the Sansa doesnât support.
Iâve always thought it funny they use that word âprotectedâ. What are they protecting us from? From using anything not made by Apple?
Message Edited by bdb on 08-02-2008 04:17 PM
The iTunes plus ones arenât protectedâŠ
Yeah, pretty much!
Not having a Apple, I canât say for certain, but I believe Itunes music is in a âApple-onlyâ format. I think you have to download to your computer, burn to a CD, then rip the CD back to your computer in .mp3 or .wma format.
So, yes, I think you can do it; it just requires a few more steps to work. I would also think that all that converting between âlossyâ formats might result in low-quality music?
Well, to get more specific: âiTunes Plusâ isnât DRM-restricted, but it is in a format that Sansa doesnât support. Its not âApple-onlyâ; its an ISO-standard format and some other players do support it.
The burn/rip method is the most practical way of getting iTunes music onto the Fuze. If you use iTunes for all of that (specify mp3 as the âimportâ format), itâll retain the music tags.
For non-protected files (that is, not .m4p), Media Codershould convert to mp3. Otherwise, the burning and ripping process described above is your best bet.
Buy mp3s from Amazon, Emusic, etc., and theyâll play in an Ipod AND in a Sansa. Â
Yeah, I was just saying that plus can be converted
My friend has iTunes, and he has to burn/rip for his Sansa (He doesnât buy music from it anymore, but he still has his old songs)
