my sandisc 32gb cruzer blade not working.its not detecting on computer or any other device.could you tell me what to do to work pendrive properly.
You could check the blade’s electrical contacts to make sure they are clean. If the blade is new you should return it to where you bought it or to SanDisk for a replacement.
