Best external hard drive for MacBook Pro
I just got my first ever MacBook product. I have a MacBook Pro with limited storage space which I just figured I could always get an external hard drive after purchasing. I’m not too sure what would be the best external hard drive to use https://trackeasy.fun/usps/.
I’m looking for something that is at least 2TB and my budget is about $150.
try that, it compatible with USB-C and USB-A port
SanDisk Extreme Portable SSD (2TB), Toshiba Canvio Gaming (2TB HDD), and LaCie Mobile Drive Secure (2TB HDD).
Considering the performance, capacity, and your budget, these three models are more suitable for you. And if the hard drive is your external Time Machine hard drive to restore your Mac data, I would suggest you choose the most reliable one. In case sometimes the Time Machine couldn’t back up to an external hard drive.
