I am in the market for a reliable pair of bone conduction headphones and could use some advice. I mostly use them for music, phone calls, workouts, and commuting, and sound quality is my top priority. Budget is not a major concern. I just want something that performs well.
After reading expert reviews from trusted sources like TechRadar, CNET, and Wired, two models consistently stand out as top recommendations:
SHOKZ OpenRun Pro
https://www.amazon.com/Shokz-OpenRun-Pro-Conduction-Built/dp/B09BVXT8TJ?th=1
It is lightweight and secure fit, with advanced bone conduction technology. It provides IP67 waterproofing, up to 10 hours of battery life, and very good sound quality.
Run Plus Bone Conduction Headphones
https://www.amazon.com/mojawa-Run-Plus-Conduction-Headphones/dp/B0C374SW7J?th=1
It is durable, comfortable open-ear design. It provides IPX6 waterproofing, around 8 hours of battery life, and is well-suited for workouts and outdoor activities.
Both are very good and the price is also affordable. Both are attractive when looking at the specs, but the actual feeling of use is different for each person. The priority in my case is to be comfortable for long hours of use, clear sound for calls and music, and durable. My budget is flexible but preference is only best quality.
So which one would you recommend? Any advice or personal experience would be appreciated.
Thanks in advance!
