I notieced when I got my sansa fuze new, I pulled it out of the box and I noticed that it was already 3/4 of the way charged so I started using it. It says that it will be working just listeaning to music for 24 hours. Well I noticed that is lasts for about 2 hours from the full charge point and then dies. What is the problem here?
Be sure you have the latest firmware on the device (1.01.11). Charge your player for 3-4 hours and test again. In addition, higher bit rate music will decrease battery life.
I really don’t care if they do or not. But anyway, just make sure to charge your unit fully before using it. Factory charge degrades over time and isn’t exactly the best representation of battery life in the unit.
Higher bitrate results in larger files, and more bits that have to be read to play a file. Its a significant issue with disk-based players because the disk is the most power-consuming component. Its likely to be less of an issue with flash-based players because reads don’t require so much power. Probably the LED is the biggest power consumer in the Fuze.
I’ve had my sansa for about a year and the battery cannot be recharged. The Best Buy where I purchased it no longed sells sansa MEP and told me to contact the vendor. Where would I buy a battery, or should I send the sansa back to the manufacturer?
