New My Passport. When bkup frpm MacBook with two accounts will they be seperate or what is the process to do so?
How can I backup my iPad to the My passport HD?
Thank you…
curtisin1
Thank you…
curtisin1
That depends on the backup process itself, not on the Passport drive. For example, if you use Time Machine then it will create a full image of your entire system.
In order to copy files from a tablet/phone, you will need to use a computer as a bridge between the two.
Regards,
