I picked one up today hoping to resolve my issue with transferring/backing up 4K videos to my computer. This drive seems to work well enough but I’m running in to the same problem as always, whenever I copy a video it compresses the file. I don’t know why it does this, it’s a 128gb drive and I only have 64gb capacity iPhone so I should just be able to get the full uncompressed file, but apparently not. Files copy to around 50% of the size they should be. Is there a way around this? I’m really happy with the product otherwise.
I picked one up today hoping to resolve my issue with transferring/backing up 4K videos to my computer. This drive seems to work well enough but I’m running in to the same problem as always, whenever I copy a video it compresses the file. I don’t know why it does this, it’s a 128gb drive and I only have 64gb capacity iPhone so I should just be able to get the full uncompressed file, but apparently not. Files copy to around 50% of the size they should be. Is there a way around this? I’m really happy with the product otherwise.https://192168ll.onl/ https://xender.vip/ https://testmyspeed.onl/
my issue has been solved!!!
How was it solved? I have the same problem.
The fault may be in your computing system settings.
It has nothing to do with the drive.
Drive just stores the data and does not decide whether to compress the file before storing it.
That thing is done by the system that tries to copy the file into the drive.
I hope this helps!
Regards.
Ruskin.
@tovino77 wrote:
I picked one up today hoping to resolve mcdvoice my issue with transferring/backing up 4K videos to my computer. This drive seems to work well enough but I’m running in to the same problem as always, whenever I copy a video it compresses the file. I don’t know why it does this, it’s a 128gb drive and I only have 64gb capacity iPhone so I should just be able to get the full uncompressed file, but apparently not. Files copy to around 50% of the size they should be. Is there a way around this? I’m really happy with the product otherwise.https://192168ll.onl/ https://xender.vip/ https://testmyspeed.onl/
ok got it thanks for sharing this.
