Is there any difference between the 128GB extreme PLUS microSD card here:
and the 128GB extreme microSD card here:
https://www.amazon.co.uk/dp/B06XX3X9JD/ref=psdc_1345826031_t2_B06XYSVX64
As far as I can see they both seem exactly the same with read speed up to 100MB/s, write speed up to 90MB/s, with all the same classes:class 10, A1, UHS-1 U3, V30
If the extreme plus is actually any better than the extreme then I might get it as it’s only £6 extra, but if there isn’t any difference I don’t want to waste £6 on nothing.
Thanks
