In my other phone it said same.
This doesn’t mean it wouldn’t work on pc.
Sometimes detects not on android but will on other devices like a computer?
Sandisk Ultra Plus 128GB
[If the data is not important]
Attach Sd card into WindowsOS machine,
>>If detected, _RIGHT-CLICK _the drive, _CLICK FORMAT _, Uncheck QUICK-FORMAT , wait for it,
reattach to your phone
>>If not detected, reply and I will tell some software that will help you in your issues
[If the data is IMPORTANT]
Reply to me…
