Have 64 bit pc
Have iexplorer 10
Have java 32 b
Web wd2go does not run after installing java update, before worked correctly
Why? Solution?
Hi
Here is the answer: I reinstalled Java 7 25, and the wd2go web came correctly to life, works according to description,
nevertheless even after signing out from WD2Go, MYBookLive and the shares are still available in Explorer.
Is that correct or not?
So finally it works and that is the most important.
Greetings to all, and have a good time.![]()
Edmond
