am not able to access admin browser
I am not able to access the admin portal of my PV503Z. I can access my personal page, but no other options to manage the device. Any assistance is appreciated.
To access the admin portal of your PV503Z:
  • Check your admin login details.
  • Try accessing via the device’s IP (e.g., http://).
  • Perform a factory reset if needed.
  • Clear your browser cache or use a different one.
If it still doesn’t work, contact support.
Hi @mfg0258, as already mentioned by @johnjacobb40, do check your admin login credentials and try accessing the device using its IP address (e.g., http://192.168.x.x). In addition to that, here are a few more steps that might help:
  • Make sure you’re not logged in with a regular user account, as that may limit access to admin settings.
  • Try using incognito/private mode or a different browser to rule out any cache or cookie issues.
  • If the admin portal still doesn’t open, you can reset the device to factory settings using the physical reset button (if available).
