I have two MP3 players and I’m trying to get the “recordings” (i.e. voice recordings) from one MP3 to another. The recordings are on one MP3 player and I also have them burned to a CD. Can I do this? If so, how?
Thanks,
Bridget
Thanks,
Bridget
which mp3 player? I guess it would work as long as the file formats are right.
Probably best if you convert the .wav files that the sandisk creates into .MP3 files.
It might matter where the file is saved on the particular mp3 player, assuming its not a common .mp3 file that most players support.
Thanks. I think I found the answer in another posting.
-Bridget
