Access delayed 2-3 sec
my WD My Passwort Essential SE with 1 TB has always a delayed access …
if I browse through folders, I double-click … 1, 2 … it opens
when I´m listening to music, double-click on a file … 1, 2 … it starts to play
if the song is over and the next song of the playlist starts, I hear it for 1, 2 seconds, then I´ve 1, 2 seconds delay and then it continues to play …
with movies it´s the same …
even when I browse pictures …
that´s quite annoying …
any suggestion what to do / change / test?!
I have the same problem as the user Drop-D
I had 320gb old one and never a problem, an excelent one!
I bought 1tb to have more space, I work with it, DJ and VJ in a Bar… and I have to stay using 320gb instead of new 1tb.
Always a delay between new playbacks, fastforwards or changing mp3 or videos. TOOOOO SLOWWW
NEED HELP ASAP!!!     or only solution…I will sell it to a friend and buy other brand to test
HELLOOOOO???
WD staff to try to give us an answer over this bad function issue???
thanks!
This is not WD tech support.  You’ll need to contact them if you’re looking for help from them.  You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
I have exactly the same problem as Drop-D.  If I haven’t accessed my WD Passport Essential SE in the last few seconds, my next access is delayed a couple seconds.  This is true on either write or read access.
I’ve been in touch with WD tech support on this issue. They suggested I make sure my drive has the latest firmware. To this end, I selected my drive and OS from http://www.wdc.com/wdproducts/wdsmartwareupdate/ and downloaded the firmware installer. It upgraded my firmware from 2.011 to 2.019. This didn’t solve the problem, but it seemed to reduce the delay to about 1.7 seconds.
