Morning
Never had a back up device, bought this and was hoping it would be plug and play, drag and drop…not so!
I’ve got two work PC’s and need info stored off both. I originally started on the old PC< Windows XP 2002. I’m still at the screen where it’s ‘catagorizing your files’ although its been doing that all night and there’s only 33Gb to store and so I presume there’s something wrong, but dont want to stop it running. So if someone could help me with this; much appreciated!!
Secondly, I then need to hook it up to the new works PC, which is an HP Notebook Windows 2007. Can I just go through the same process as with the od laptop or will it override that back up??
Any help would be much appreciated!!
thanks
Max
