Good morning, and thanks for reading
After thinking about it a lot I thought about getting all my files sorted from my PC’s with W10 and W7 respectively and other hard drives, and I bought an external 8TB MyBook disk to unite them , it was enough (I have calculated about 6TB of files). Everything was “fine”, until after a few days of adding data I realized that the numbers did not match. The result is that filling only 2.8 TB or so was missing only 0.7 TB. I was surprised, I checked with other applications to check the files and their sizes and the numbers says the same, the final result was given to me by CHDSK:
3519025152 KB of total disk space.
2274243584 KB in 4107518 files.
362775552 KB in 354248 indexes.
0 KB in bad sectors.
2048 KB in use by the system.
882003968 KB available on disk.
1048576 bytes in each allocation unit.
7630852 total disk allocation units.
861332 allocation units available on disk.
I also tried it with an Ubuntu 17.10, which said me the same numbers, checked the physical state of the disk and it is good but the numbers are wrong: The properties window says it is 8TB disk but that it has only 0.9 free (having used, I repeat, about 2.8 / 2.9 TB)
The hard disk is formatted in a single exFAT partition.
Please,does anyone have any ideas?
Thank you
