im am using a mac, and i just want to ask if there is a way to back up specific files or folders to the external harddrive thanks
Unfortunately, if you are using WD Smartware you will not be able to backup specific files or folders, the WD Smartware does not have this capacity. If you wish to do so, you will need to use another backup software or manually backup your data.
