octopod
September 12, 2015, 12:35am
1
Hello
I want to buy this device but i cannot find anywhere the following information which is very important for me:
can it display long track titles in the library and/or long filenames in the folder mode (60-80+ characters long)?
is there a way to play 1 track from an album/folder then it stops? need to use a “quick playlist” + repeat mode off?
Thanks in advance
1.) No
2.) You could add the 1 song in question to the GoList, then play the GoList (on-board simple playlist function). It should stop after that 1 song has played.
octopod
September 14, 2015, 5:34pm
3
You mean it won’t even scroll the filenames?!
My wife owns a Clip+ and it is able to do it…
The Clip Sport & Jam are very different machines than the Plus or Zip models.
Please see this thread , and particularly the response by drlucky.
