Hi Everybody - hope that you can give me some advice
1Tb WD Passport Drive - WDBYNN0010BBK-0B
Has had data written onto it and then in storage for about 6 months
Now when I plug it in
It is detected - PC makes sound when plugged in
Shows up on “Device Manager” under Disk drives as - WD My Passport 25E1 USB Device
Shows up on “Safely Remove Hardware and Eject Media” as - Eject My Passport - and ejects if clicked
The drive does NOT SHOW on File Explorer
The data was written on a PC running Win 7 - now I’m trying to access using a PC running Win 10 - I actually tried on the old Win7 PC and same issue
TIA for any advice on what to do
