please help me to retrieve my data
This usually means that the driver (which does NOT come from Seagate; this driver comes from Windows) has lost communication with the drive or the driver has crashed .
The Code 43 error is one of the multiple Device Manager Error. This error occurs when Device Manager stops the hardware and reports the unidentified problem.
.This Error Code can appear on all recent Microsoft Windows Operating System, ranging from Windows 10 to Windows XP.
Here are the ways to fix these error:
- Restart the System.
The first and foremost approach to resolve the issue is to restart the system. This is because a mere process to unplug USB is not enough. Thus, it is always advisable to shut down the system and restart after few minutes.
Steps to use this approach are:
- Unplug the USB Drive.
- Turn off the System.
- Allow System to set for at least 5 to 10 minutes.
- Plug-in the USB Drive.
Method 2: Update the Driver
Another solution to fix the error is to check and update the driver. Reason being, the available driver may not be up-to-date. Thus, installing the latest driver can most probably resolve the issue.
Steps to Update the Driver are:
- Go to Device Manager.
- Right-click on the desired Driver.
- Click Update Driver Software.
- Lastly, click **Search Automatically for Updated Driver Software.
- Additional tip: if the current driver is up-to-date, just to be on safer side uninstall the driver first and then reinstall it.
Method 3: Diagnose in the Device Manager
Diagnose in Device Manager is also a great way to overcome the issue. Check out the steps to avail maximum benefits from this option.
- Click on Windows Icon and type Device Manager.
- Double Click on Device Manager.
- Explore the list of the installed devices.
- From the list, identify the malfunctioning device.
- Right-click and choose the Uninstall option.
- Click Ok to uninstall the device.
- Now, in Device Manager, right-click on the Computer Name.
- Click Scan for hardware changes(Device manager is going to scan the system and reinstall the device automatically).
- Right-click the device and Click Properties.
- On General Tab of the device’s property box. It shows a message that “The device is working”
Method 4: Update the BIOS
An outdated BIOS is also the reason for the code Error 43. To fix, just update the BIOS.
Hope these methods will help you out.
